Help locating Clutch Bell
Hey Guys:
I was hoping someone can help me out locate a clutch bell. I have a pacesetter funny car that had a Solo engine in it. I recently got a 62cc Zenoah engine that I want to use. And as luck would have it, the clutch on the Solo engines are bigger than the the normal 54mm clutches. and the clutch thread size is opposite and not the same size. so I need to get a zenoah clutch bell that matches the one in the pics or as close as possible. I can get it machined down if need be. I DO NOT WANT TO CHOP UP THE FRAME in any way to get the clutch to work. the dimensions on the clutch bell shaft-end are 1.4 inches long and 0.5 inches OD. any help would be greatly appreciated.
