Board index » Collectable 1/4 Scale » Car Discussion
Post new topic Reply to topic  [ 12 posts ]
 Post subject: 1/4 scale pro stock chassis plans or dragster
 Post Posted: December 14th, 2015, 4:57 pm
man i hope you guys can help, ive been beating my brains out looking for some kind of plans for a chassis for a 1/4 scale pro stock or dragster is there anywhere that exists. looking to build my own chassis looking for plans. HELP
 Post subject: Re: 1/4 scale pro stock chassis plans or dragster
 Post Posted: December 30th, 2015, 8:15 am
Hey mate sorry no one will help you ,,Its about just making your own design and stuff,,not many here want to help In regards to chassis designs its really just a personal design to your likings,,,wish I could help you,, it really is very simple to make your own chassis and just add commercially available hardware,,
David
"The Chase is better than the catch" RIP Lemmy Kilmister MOTOHEAD
 Post Posted: December 30th, 2015, 8:44 am
hi, I will have a weld your own kit for a top fuel rail soon if you want one
 Post Posted: December 30th, 2015, 1:10 pm
Here's my build. Your pretty much on your own. I was. I did have some help from members. I started mine with no engine. I was lucky the engine fit after the frame was built. You will need to research this build. What type of rear wheels, GoKart or wheels from Bishop Racing .What size engine. I used a Zenoah G62. Frame design. Belt axle or a Skellenger rear end. A full scale Top Fuel wheelbase is 300" so 1/4 scale is 75". etc etc. There are pictures of dragster frames on here. You will need to search for them. viewtopic.php?f=30&t=2534
 Post Posted: December 30th, 2015, 5:54 pm
A good starting point would be to buy a plastic scale model kit (there are all kinds of them on ebay) and use it as a guide / or for inspiration.
 Post Posted: December 31st, 2015, 10:00 am
That's exactly what I did Kaye. You can see it in the first picture in my viewtopic. lol.
 Post Posted: December 31st, 2015, 4:10 pm
I'm doing it right now with a 1/25 plastic model VW Beetle :)
 Post Posted: December 31st, 2015, 8:43 pm
thanks guys i appreciate the reply's i figured as much just thought id ask.
 Post Posted: January 1st, 2016, 6:13 am
in the begining
 Post Posted: January 1st, 2016, 9:40 am
Using plastic models as a guide / template:
(a) Fill plastic model body shell with spray can insulation foam (cover window and wheel openings, etc.), (b) Draw lines across body shell at suitable / equal spacing. (c) Saw cut through body to obtain slices of cross section. (c) Copy / enlarge cross section slices. (d) This is a good low tech starting point.(e) Or spend lots of money on a 3D scanner and take it from there
 Post Posted: October 8th, 2016, 8:57 am
did you do the frame yet.if not
it should get you started
 Post Posted: October 8th, 2016, 9:16 am
Users browsing this forum: No registered users and 8 guests
