honda has come out with trhe gx35cc overhead cam engine once its stripped of its shrouding it looks like it will shoehorn into a marder chassis under the roll bar. Over at ASMBA Bob has been doing much R&D on this engine with cams and carburation.... how does 13,000 rpm and 5+ hp sound? the air blast from the flywheel is about 35 mph so if the engine had the proper ducting running without the cooling shroud should be enough
link to HONDA GX 35 hop ups
http://p202.ezboard.com/famericanscaleo ... ationfrm41
4 Stroke Honda update
Use no way......as WAY
fastrat, somehow I missed this post before and now the link is dead. I am very interested in this project. More info?
if you like Kawasaki they have a new 4 cycle too
http://www.motogarden.com/th48.htm
not to much power only 3hp @ 7000 rpm
