1/4 scale mini pick up
oldskoollews
Re: 1/4 scale mini pick up
Post by oldskoollews »
they way i would do it (without any fancy machine or press) is to get a dremel or another type of small cutting tool with a very thin blade, mark out where you need the louvers on the panel in question leaving enough gap between them so you can "flare" them out so they look right, get a block of wood, and carve (or using an angle grinder carefully with a sanding pad to get the shape) out of 1 edge the reverse of a louver, sort of like a photo negative, then with a hammer and chisel, carefully knock the louvers open into the negative on the piece of wood, if you do it carefully enough, you can do them as large or as small as you like
i really hope this makes sense funky, if not i could always do some myself on a scrap piece of steel and post up a "how to" to show you what i mean
Annihilator
Post by Annihilator »
keep up the good work,looks great. just remember weeeee love pics,thanks for sharing
oldskoollews
That's even better then as I always well document my builds with plenty of pics, no sheet steel yet though so no progress to report :-( got my fingers crossed it turns up next week so I can crack on
oldskoollews
some progress though now, got some sheel metal and contined to build the body...
BOOSTED-ELKY
Post by BOOSTED-ELKY »
I like it! Very Custom!
Keep up the good work!
oldskoollews
bit more progress, made a start constructing the other rear side panel...
oldskoollews
bit more of an update, got the rear side panels finished and tacked into place, and made up a rear panel (only did it flat, the detail will be in the numberplate and rear lights)
BOOSTED-ELKY
Lookin Great!
You're making lots of progress!
oldskoollews
After some thought, i decided the original chassis was gonna weigh a fair bit, not so good for speed! so have had a rethink and a redesign and have come up with this...
the plate in the middle is where the 50cc minimoto engine will sit
after some more thought, i realised i had to modify the chassis at the rear to allow me to fit my bearing block (which is actually a minimoto wheel centre smoothed down! = nice and light = :D
oldskoollews
stared on the independent front suspension
oldskoollews
its now rolling (the rear axle however has gone away for machining) heres a pic... ;)
oldskoollews
The plug i am working on to make a fibreglass removeable front end ;)
oldskoollews
Made a start on the new chassis today, its gonna be a monster considering that engine is a mini moto one! And I still need to finish the rear end of the frame!
And the quality of the welding ;)
oldskoollews
Started making up the rear end today, done the rear corner light panels, just need to notch them a little to bring the tops in so its in scale
oldskoollews
