New Build
Vcut670
New Build
Post by Vcut670 »
I am building my own body,,I have the contacts for a cnc plug but I just want to se if I can create something my self.. well I got a rough drawing se how I go this a proper 1/4 scale size drawing
Vcut670
Re: New Build
Post by Vcut670 »
Aussie car 1971-74 HQ Holden 2 door coupe Monaro GTS 350chev
RcBurnout
Re: New Build
Post by RcBurnout »
Go online and search the car. Enclude in the search dimensions. A bunch of info will come up telling you stuff like wheel base, overall length, width and height. Then apply those dimensions to your drawing you have rendered and make the adjustments to bring it to scale. Same applys for the frame and suspension. I always make the body first then the frame to suit. But it's your build. Do as you see fit
Imagination feeds creativity
Vcut670
Re: New Build
Post by Vcut670 »
Thanks I have done that all measurements and they are 1/4 scale ,,I am using the 1/5 scale wheels 170mm at moment to fill out the wheel arches ,,
David
Vcut670
Re: New Build
Post by Vcut670 »
Started cut on one side ,,,
Re: New Build
Vcut670 wrote:Aussie car 1971-74 HQ Holden 2 door coupe Monaro GTS 350chev
This car is absolutely gorgeous in silver; a very fluid shape that's so easy on the eye.
Re: New Build
half the car reminds me of a 72 GTO
Vcut670
Re: New Build
Post by Vcut670 »
gotta start fabricating/shaping/filing
now..
