baja 5bss and caravan
If you have an RC that is not 1/4 Scale you can still post here for full range discussion on all types.
rockypro1
Post by rockypro1 »
hi all, Heres a video of a 1/5th scale baja and caravan that i built. i built the baja 5bss back in 2008 and changed its a lot since, now its called baja 5bss Ultra-wider its got a 29cc billet engine with 2mm+crank,V.2 dom silienced pipe,enclosed clucth bell housing,vented clutch bell,gearing is 18-56,nerf bars,craft werks roof light pod holder,FLM Ext alloy arms,8 shocks,Hostile alloy rear hubs,rear width 27",front width 26",weight 35lbs+,
the the caravan i built also, first i built a car transporter and then i built a caravan that fits down onto the car transporter so now its a two in one, cheers
http://youtu.be/ZCG47zIXfeM
No Guts No Glory
