1/4 Scale Street Truck
Post by bentley marshall »
been working on a street truck chassis to go with the truck body plug ive been working on its been to cold to do any fiberglassing so ive made a start on the chassis for it ...
engine is a 39cc water cooled pocket bike engine
heres some pics
Re: 1/4 Scale Street Truck
got the front end all bolted up and shocks on
some done on the steering still needs a bit more work
Looks good Bentley. What are you going to use for side rails. Geoff
the sides will be alloy once i finished building every thing and i am happy with it i will use the wood as a template to cut them out
K
Post by K »
Mate: I take my hat off to you, you're doing a fine job, I'm eagerly following your progress.
Kevin
FuNkY mOnK wrote:Nice job Bentley, what's planed for the rear mount and suspension?
not 100%sure how im going to do the rear end yet i dont think i will use the toro diff
more than likely just use a single belt drive set up like this
yeah still thinking about the rear end the motor puts out about 7hp so it will need a set up that will help with traction :D
allso need to put a brake on it too some where :?
