Aston Martin, project.
Re: Aston Martin, project.
Thanks mate.
The body is ready and its chassis time.
I'll start with hub - calliper part, always cast alum , 22mm piston dot oil use.
The difficult step is the prototypes ,different for each wheel (symmetrical ) and now are ready to make the mould and the final parts.
Uploaded with ImageShack.us
The prototype chassis , alum + acetal .
Its a strong build , low cost but with difficulties to screws.Finally I'll make it all alum ,on different lines on the same think.
Servos have position in ( on ?) chassis so i dont need many parts.
Double steering servos , double arms and horizontal absorbs as always but to other direction .
Very nice.
- eightman
it's so wonderfull to manage to build his own car from a to z!
all black parts ares in acetal? (POM)
i wonder what you call low cost? will you manage to stay under 1000€ complete car unpainted? (without radio)
i also wonder what it will do with only one shock by axle, like old Yankee cars? i could be easy to test
anti-roll bar system?
eightman wrote:it's so wonderfull to manage to build his own car from a to z!
Yes, all blacks are acetal.
Its only a test for final chassis and costs 45 euro only as acetal.
There is one shock for esch axle. I made only the one side for the test
Yes, after the casting , lathe and milling to take the product.
I use seals and pistons of bikes spares (HOPE or SHIMANO ).
- eightman
it's incredbile, i won't be surprised the day you will make you own engine!
Thanks Stef.
Engine as new project ? Great idea.
Maybe into next 50 years!!!!!!!!!!!!!!!!!!!!!!!
Its a time to make a disck rotor to my rim but and a new rim centre.
Disck's holes position are suitable for centres with 10 arms.
I hope that all will be beter, after powder coating, because now all are silver - alum.
- eightman
no ceramic disc?!!!
nice job! is it speacial alloy used to make a brake disc?
eightman wrote: no ceramic disc?!!!
Thanks Stef.
Always inox 2mm to discks,Works great.
nice mate you know what to do keep up the good work
