I need a set on wheels for my DWA. I'd like to use a set of tires that where originally manufactured for a yankee F1 car. The mounting diameter of these tires is 115mm, can somebody tell me what i should look for?
Can i use Raco rims on DWA hubs?
DWA ( Raco? )Wheels
Re: DWA ( Raco? )Wheels
they are slightly different but you can make them work.
So does anybody knows what are the mounting diameter options for raco wheels?
do you mean width? Or the Outside diameter?
Outside diameter
the wheels are about 4" OD. The tires come in a variety but the ones that are easy to get would be 6.00 or 6.5" OD tires.
Thanks Mike Casey! U Da Man!!!
