New Build
New Build
I am building my own body,,I have the contacts for a cnc plug but I just want to se if I can create something my self.. well I got a rough drawing se how I go this a proper 1/4 scale size drawing
Re: New Build
Go online and search the car. Enclude in the search dimensions. A bunch of info will come up telling you stuff like wheel base, overall length, width and height. Then apply those dimensions to your drawing you have rendered and make the adjustments to bring it to scale. Same applys for the frame and suspension. I always make the body first then the frame to suit. But it's your build. Do as you see fit
Imagination feeds creativity
Re: New Build
Thanks I have done that all measurements and they are 1/4 scale ,,I am using the 1/5 scale wheels 170mm at moment to fill out the wheel arches ,,
David
David
Re: New Build
This car is absolutely gorgeous in silver; a very fluid shape that's so easy on the eye.Vcut670 wrote:Aussie car 1971-74 HQ Holden 2 door coupe Monaro GTS 350chev
Re: New Build
half the car reminds me of a 72 GTO
Re: New Build
gotta start fabricating/shaping/filing
now..
now..
