Page 1 of 2
Homemade largescale diff?
Posted: December 17th, 2009, 11:32 pm
by Dirty_Vinylpusher
Been thinking about a homemade diff for largescale applications, and today I got a couple of old grinders and started tinkering a bit.
As I don't have access to a lathe, cnc thingy or anything like that, I have to try to find things that work together, and this is where I'm up to so far.
OPTION A:
Grinder heads mounted on the chassis with large sprocket somehow mounted on some casing also holding the smaller gears.
OPTION B:
I discovered that the holes in the pocketbike sprocket and the holes in the grinder plates line up perfectly.
With this setup, all that would be required is a bearing on the end of each axle, and a way to secure the bolt holding the small gears.
Basically, the whole setup will rotate.
Given the limitations of my workshop, I will most likely go with this setup.
If this works, I will have a large scale diff for about $15.
Re: Homemade largescale diff?
Posted: December 18th, 2009, 10:27 pm
I found a piece of square tubing that will fit perfectly on this setup and cover the gears and the bolts.
The small gears can be attached to it somehow, I'm sure.
The tubing will cover the red area in the picture.
Posted: December 18th, 2009, 10:56 pm
by troppo
I reckon your onto a winner there mate.
You mention a tube covering the red area, could you use that to locate the bolt holding your small gears?
Posted: December 19th, 2009, 1:04 am
For sure.
I do believe I mentioned that in my previous post.....
Posted: December 19th, 2009, 3:51 am
by Juiced Drag Racing
Looking good!!!!
Ed
Posted: December 19th, 2009, 5:37 am
by troppo
Dirty_Vinylpusher wrote:For sure.
Sorry mate, you said square tube i thought you were talking about crush tubes on the bolts.
The tube i was talking about was what i thought was a round tube large enough to encase the whole diff assembly.
I make silly mistakes sometimes, but thats life aint it
Posted: December 19th, 2009, 6:30 am
Nah you're ok mate.
I see where you're coming from now.
So
The square tube I'm talking about will cover the whole assembly as highlighted red in the picture.
I can't use a round tube as it will get in the way of the bolts holding the two grinder halves together.
A square piece will allow the bolts to run all the way through, right in the corners of the tube.
It's a pretty tight setup with not much room to spare.
The small gears can then be mounted on/in this tube.
Posted: December 19th, 2009, 6:44 am
by troppo
You could easily do a crush tube setup with a sheetmetal wrap around the body of the diff. If i understand what your saying the whole diff will rotate so a sheetmetal casing with the crush tubes will make it a bit tidier , and you could have the casing sealed but easily open-able for repairs.
Just thinking with my work brain (not easy at this time of night after a beer or several lol) .
I can see what your doing and its beautiful in its simplicity, but oh so bloody brilliant.
I dip me lid to ya
Posted: December 19th, 2009, 2:11 pm
Posted: December 19th, 2009, 3:09 pm
by troppo
Jesus, that could have been made for that, its a perfect fit. A bit of 75x75x2mm rhs, i woundnt have thought of it.
Great work, now you just need to sort mounts and axles and you have a complete dif assembly
Posted: December 19th, 2009, 7:51 pm
Yeah it's a leftover piece of a colorbond fence post from a job I did a few years back.
Knew it would come in handy one day.
Posted: December 23rd, 2009, 2:41 pm
Posted: December 24th, 2009, 2:14 am
by K
DVP: I'm really enjoying your project, keep up the good work.
Kevin
Posted: December 24th, 2009, 2:36 am
Thanks.
I enjoy tinkering.
If it works, it's a bonus!
Posted: February 12th, 2010, 7:08 pm
by merlinsteve
awesome idea, I think it will do quite well.
Those grinders take a fair kick on startup too so I reckon it will hold up to almost anything.
