Modded G2D???
Modded G2D???
Can someone please help me ID this engine? It looks like a G2D but with a red cover. There also seems to be an adapter for the spark plug. Is this a G2D, modded G2D or other? Your input is appreciated! Thanks in advance.
- Venomusss
Re: Modded G2D???
It looks like a G2D. Look on the crank case for the number 1140. The number 1140 will also be located on the cylinder head behind the flywheel cover. Also look to see if the cylinder head uses 4 bolts to mount to the crank case.
The spark plug looks like it is using an adapter. They probably wanted to run a hotter or colder plug or even a higher quality plug.
