4 Stroke Honda update
Posted: April 13th, 2006, 8:04 am
honda has come out with trhe gx35cc overhead cam engine once its stripped of its shrouding it looks like it will shoehorn into a marder chassis under the roll bar. Over at ASMBA Bob has been doing much R&D on this engine with cams and carburation.... how does 13,000 rpm and 5+ hp sound? the air blast from the flywheel is about 35 mph so if the engine had the proper ducting running without the cooling shroud should be enough
link to HONDA GX 35 hop ups
http://p202.ezboard.com/famericanscaleo ... ationfrm41
