Repairing a Raco fuel tank.
Posted: April 29th, 2012, 11:23 am
by PTModIT
Hi, Has anyone repaired a Raco fuel tank successfully.I found a leak at the seam closest to the engine.It's about 2"long.It's a clean split.If you have what did you use to seal it.Thanks.
Re: Repairing a Raco fuel tank.
Posted: April 29th, 2012, 4:16 pm
by iggmon72
I have used CA glue with baking powder... That works well...
Posted: May 1st, 2012, 7:21 pm
by Venomusss
I took an old cheap radio shack soldering iron and hammered the tip flat. You can slowly slide it along the seam and it will melt everything closed. Clean the tank out first . A hot knife will also work. This has beaten any glue I have ever used and I have never seen one fail from a repair using this method. It gives a nice smooth repair. In most cases you cannot even tell it was repaired.
Posted: May 1st, 2012, 8:31 pm
by PTModIT
Thanks for the tips.
Posted: May 1st, 2012, 10:31 pm
by bobjeffreson
Rapid Fix.
Anyone else tried this product. I've found it to be quite amazing.
http://www.google.com/url?q=http://www. ... jBzebdhGoA
Posted: May 2nd, 2012, 4:37 am
by PTModIT
Hi, I'll look for it where I live.Hopefully at any automotive store.It looks like CA glue and baking powder .Thats what iggmon used. Thanks.
