Wcm axle pulley needed HELP!!!!!!
Posted: February 26th, 2022, 3:09 pm
by steve g
Hello, I’m in need of a WCM belt drive axle pulley in restorable condition... both halves or one half is fine if the diameter matches what I have .. please let me know.
Thank you,
Steve
Re: Wcm axle pulley needed HELP!!!!!!
Posted: February 27th, 2022, 7:15 am
by anytimerc
I converted all mine to ball diff drive. I could use more too. I have been looking for a long time. Chain drive would be easier.
Posted: February 27th, 2022, 7:54 am
by steve g
anytimerc wrote: ↑February 27th, 2022, 7:15 am I converted all mine to ball diff drive. I could use more too. I have been looking for a long time. Chain drive would be easier.
I would actually prefer to go to chain but I can’t figure out how the transmission comes apart... is it pressed together?
Posted: February 27th, 2022, 9:34 am
by anytimerc
If it has the timing pulley: I haven't figure it out either. I can get the clutch shoe off but the clutch drum is welded on to the shaft on other side. I would just heat the clutch with a torch and the braze weld will come off: If tig welded then it will require a bit more work. If you do figure out how to remove the timing pulley: I would like to know how without destroying it.
