Aston Martin, project.
Vass
Post by Vass »
I'm back with new project.
I'll try an Aston Martin, 1/4 scale. Firstly, the body, from 2mm lexan on vacuum mold.
Length:112cm , Width:540mm , Wheelbase: 650mm.
I took a bburago 1/18 AM, as a model. One week later and hundreds calculations and patterns i'm here.
This project is with the close collaboration of my son Tassos.
Uploaded with ImageShack.us
Re: Aston Martin, project.
TAKING SHAPE!!!! Sweeeeeeet.
Vass
Post by Vass »
Vass
Post by Vass »
The fender flares set it off!
laidback383
Post by laidback383 »
That looks great! I'm helping with a 1/8 scale build. but my dream is a 1/4 scale monster truck build. You have raised the bar. well done.
Vass
Post by Vass »
thanks mates.
eightman
Post by eightman »
wow i haven't seen this post/
i knew you build fantastic chassis, now you're on the way for a monument body of 1:4 scale!
you forget to say your pattern were hand cut, no CNC isn't it! Very long job and i think it will be nice!
you plan to form Lexan on this mould or you will do a resin mold...?
Stef
my stuff : RC bodies
Vass
Post by Vass »
Thanks Stef,
.... hand made, of course.
I would like to form lexan ( 2mm ? ) but i'm afraid for the indents, largely in
mask and rear. I have 5mm deep, the mask and i dont know if i could take out lexan from mold.
Vass
eightman
Post by eightman »
forming machine will take mold... and maybe the body with it :(
maybe i can tell you just to keep a "45° shape" (red) at top of your indent or "hole"
i'm sure this will be ok 5mm for 250mm high mold.
Vass
Post by Vass »
thanks Stef.
I'll try to keep the '45 deg shape' .
Vass
Vass
Post by Vass »
A little about AM project.
- Engine : R 460 http://www.chungyang.com.tw/en/product01-r460.html
in the spirit of muscle cars.Low cost engine, without special pipes, cylinders and with bass sound as befitting to AM.
- Chassis : aluminum + stee tube. Light weight and strong.
- brakes : 4 disc rotors, hydraulic callipers
-tyres : BRP ,http://www.bishopracingproducts.com/ , maybe with home made alouminum rims
- transmission : 2 belts or chains and self lock diff
-suspension : double arms for each wheel, adjustable absorbs
My aim is a balanced, super car.
Vass
Vass
Post by Vass »
Why not ?
Vass
Vass
Post by Vass »
...a lot of working hours for a small step.
eightman
Post by eightman »
i like it ! :mrgreen:
just still wondering how you will do you vaccumforming mold...
several materials together don't like heat, and i don't like cracks... :|
i'm sure you will find a solution! (longer but better is to make negative mold then final mold)
Stef aston Fan
