Huge Skellenger lot. Perhaps the largest EVER offered
Up on Ebay. An easy 10k of profit could be made on this lot!
http://www.ebay.com/itm/1-4-scale-Quart ... 2ca2c1af32
Re: Huge Skellenger lot. Perhaps the largest EVER offered
That's tempting... I wonder what the machining would cost.
I was quoted $20-30 per rear
am I reading the ad correctly where it says that there is only one side cover in the lot?
Correct. That's what it says and shows in the pictures. Skellenger lost that mold. I modified that cover to use as a plug for an epoxy mold. It's very easy to make one and costs about $80 in material. It's the same process Conley uses. Research investment cast or lost wax process to understand.
ok Ive done some lost wax casting in the past. My uncle makes teeth. hes got all the equipment. Hypothetically if you don't sell the lot would you be interested in selling one at a time?
Yes. One center, rear cover and ring gear set for 475 ea.
ok great!! I hate to say that I hope that you don't sell the lot. Im assuming that a hub to attach the ring gear to the axel needs to be fabbed?
Yes
If you part out, i would like a stand!
oldschoolmidget
I would also want a stand if you part out.
Thanks, Anthony
Thanks, Anthony
Offering an amazing deal on this lot for a limited time. 8k gets the whole lot. OUT of Ebay.
did not sell. To make more affordable. I am going to split up and offer smaller lots at discount.
$475
Center
rear cover
ring and pinion
$75
Stand
$40
Clutch housing
$200
Ring and pinion set.
Paypal friends and family only. Prices are shipped in USA.
$475
Center
rear cover
ring and pinion
$75
Stand
$40
Clutch housing
$200
For a limited time $6500 gets most of this lot. About 20 rear ends. I will include an epoxy side cover mold. This offer is only through the weekend as I need to get this out of the house before christmas. If no takes it goes back into storage.
Off the table and going back into storage. Thanks!
