'' PROJECT '' Pro Street Beretta
troppo
Re: '' PROJECT '' Pro Street Beretta
Post by troppo »
It seems i have missed a heap of progress mate.
This build has come so far since i first found it and i have to say your an inspiration, i like to build the way you do, do it yourself and do it cheap as possible ( apart from your engine of course) your ingenuity and skill has been a real mindblower. Looking forward to more pics of this amazing build.
Cheers
Troppo
stoneyberk
Post by stoneyberk »
Thanks troppo,, I'm really not leaning towards building as cheap as possible... I'm leaning towards building something from scratch and building something that has never been built before... I was told many times a few years ago that a 1/4 scale sheet metal rear end couldn't be built... I was also told that an exact 1/4 scale replica tube chassis couldn't be built... Due to structural design issues... Well needles to say i have proven that to not be a fact... And last but not least... I just love fabricating things... I've been fabricating things for many years and found that a 1/4 scale car will be quite the challenge...
As for the engine... Yes it will be a serious chunk of change to build... And trust me... I won't cut any corners when it comes to building it up... I have spoke with a few machinist on all the necessary machining and as to date I'm looking @ about $5,000 for the crank / cam / rods / blower vanes / deck bored, etc... I can do some of the machining work myself but i will need to farm out all the extremely precise machine work... If i where to guess i would say i will have close to $10,000 in the engine once it's done... But it's well worth every penny to me... It may take me a few years to get this thing built but it's going to happen...
I won't even go into my next project.. a 1932 bantam altered.. enough said!!!!
Thanks again
stoneyberk
Well i now have the tubs tack welded in.. I over cut the tubs to allow them to fit the quarter panels, once i get the body built i will trim the width to fit... here are a few shots of them.. The rest are on my site!
Tubs 082.jpg (128.2 KiB) Viewed 8358 times
Tubs 063.jpg (128 KiB) Viewed 8358 times
Tubs 033.jpg (124.36 KiB) Viewed 8358 times
troppo
Post by troppo »
I`m eagerly awaiting your bodywork mate, everything so far has been incredible
stoneyberk
Thank you!
I think the body will be pretty much easy to form.. It's the L-body structure that's going to be a bit difficult to build, As like everything else goes my friend.. I'm not cutting any corners here.. Yes i said structure... Not just a sheet metal body welded to the chassis... It's being built like the real thing from the ground up. 8)
stoneyberk
Update: I wasn't happy with the other tube design so i cut them off and cleaned up all the weld,, I then focused on my new tube design.. there constructed from 22 gauge Cold Rolled Steel, There attached via 1/8'' pop rivets.. I still need to trim the metal along the chsssis tubes and clean / seal the inner tubes but other than that there done! As you may have noticed i didn't spend alot of time cleaning up the welds along the seams.. Why! Because there will be cloth attached to the tubs that will match the interior and they won't be visible.. Now if i were going to go with a sheet metal interior look it would be a different story.. There is more shots of them on my site! http://www.quarterscaleprostreetberetta.com/Tubs.html
Tubs Folder #2 156.jpg (120.91 KiB) Viewed 8297 times
Tubs Folder #2 098.jpg (120.89 KiB) Viewed 8297 times
Tubs Folder #2 127.jpg (131.19 KiB) Viewed 8297 times
Tubs Folder #2 144.jpg (128.73 KiB) Viewed 8297 times
Tubs Folder #2 149.jpg (124.52 KiB) Viewed 8297 times
kenazzo2000
Post by kenazzo2000 »
stoneyberk wrote:Update: I wasn't happy with the other tube design so i cut them off and cleaned up all the weld,, I then focused on my new tube design.. there constructed from 22 gauge Cold Rolled Steel, There attached via 1/8'' pop rivets.. I still need to trim the metal along the chsssis tubes and clean / seal the inner tubes but other than that there done! As you may have noticed i didn't spend alot of time cleaning up the welds along the seams.. Why! Because there will be cloth attached to the tubs that will match the interior and they won't be visible.. Now if i were going to go with a sheet metal interior look it would be a different story.. There is more shots of them on my site! http://www.quarterscaleprostreetberetta.com/Tubs.html
nice work keep it up mate
Happy birthday STONEY!!!!
stoneyberk
Thanks for the complement kenazzo2000!
Thanks for the happy birthday QSL!!!
troppo
Post by troppo »
I didnt know, so HAPPY BIRTHDAY MATE!!!
Dirty_Vinylpusher
Post by Dirty_Vinylpusher »
Happy birthday from me too!
:mrgreen:
stoneyberk
'' HAPPY HALLOWEEN GUYS ''
Well i managed to find the time to increase the size of my little work area.. It's currently 14'x14'x6' I am going to have a new garage/workshop built next year here at the house then i will move all my crap here.. It's currently located in the basement of our old home.. now my daughters home... I plan on re-sealing the south & west walls in the basement over the winter. but other than that it's > GOOD TO GO
Here are a few shots of the old work area. there are a few more on my site!
http://www.quarterscaleprostreetberetta ... eShop.html
New Weld Booth 203.jpg (129.86 KiB) Viewed 9437 times
New Weld Booth 198.jpg (124.21 KiB) Viewed 9437 times
stoneyberk
Well other than a little more welding / grinding the Fuel Cell is now built... Here are a few shots of it.. there are more pics of it on my site!
http://www.quarterscaleprostreetberetta ... -Cell.html
Fuel Cell 332.jpg (116.3 KiB) Viewed 9404 times
Fuel Cell 303.jpg (126.54 KiB) Viewed 9404 times
Fuel Cell 289.jpg (125.06 KiB) Viewed 9404 times
troppo
Post by troppo »
That looks bloody great mate, are you leak testing in the last picture?
stoneyberk
Thanks for the complements guys..
Troppo> Yes that was one of many leak test i did on it... AS you can clearly see.. The paper towel is wet. lol.. I forgot to put the Teflon tape on the fuel ports... it's good to go now!! other than welding the top on it and cleaning up all the welds... I'm planing on taking it to the shop next week sometime and spray it..
FuNKY mOnk> That cap is just temporary, it's 5/8'' x 1/2'' I'm going to build a T handle cap for it from a 3/4'' barrel mandrel.. I've got the mandrel i just need to shave it down a tad to fit snugly in the fuel fill inlet hole... Hopefully I'll have it all done and painted within a week or so.. I'm gradually getting all these components built for this thing..
Fuel Cell 347.jpg (126.66 KiB) Viewed 9379 times
Fuel Cell 345.jpg (123.53 KiB) Viewed 9379 times
