If you were going to buy a new oval chassis??
LBJ
Post by LBJ »
If you were going to buy a new oval chassis which one and why??? Thanks LBJ
sweetchassis#15
Re: If you were going to buy a new oval chassis??
Post by sweetchassis#15 »
For Ashpalt, I'd probs go a Pro1
chiefj48
Post by chiefj48 »
T.N.T. By Terry Rea....276 629 5166 good luck...
Magnum
Post by Magnum »
I would tend to also see what others are running in your area to help with setup. I bought a used WCM and it seems everyone was moving to Lightnings. No wonder I got a good deal:)
But still enough to help get setup.
LBJ
Post by LBJ »
T.N.T car looks like an awsome chassis but 2300$$$$ WOW!!!!. And thats not even a roller. Too rich for this newby!!! Thanks LBJ
chiefj48
Post by chiefj48 »
if you have any interest, i have a 2007 WCM all fresh with new bearings, powder coating, new body, fuel system, servos, and radio..ready to go, just needs battery, and paint for body...
$1300.00 plus shipping, and pay pal fees...
LBJ
Post by LBJ »
Sounds like a great deal. But I'm most likely gooing to buy a Lightning based chassis. I may go used but I have some conserns buying used. Thanks LBJ
chiefj48
Post by chiefj48 »
LBJ wrote:T.N.T car looks like an awsome chassis but 2300$$$$ WOW!!!!. And thats not even a roller. Too rich for this newby!!! Thanks LBJ
a roller is less money.....for $2300.00 you just need radio gear.....
Magnum
Post by Magnum »
LBJ wrote:Sounds like a great deal. But I'm most likely gooing to buy a Lightning based chassis. I may go used but I have some conserns buying used. Thanks LBJ
Actually you may want to keep the offer Chiefj48 has made in mind. I don't know him, but have seen him on other forums and I know you will be treated right. And I know you were not referring to him, as I too was concerned buying a car used from anyone. I ended up buying one local and even it had some parts that while provided no clear advantage, were not QSAC legal.
The reason I say this, is when I wanted to buy a car (and wanted it now), there is generally a long waiting list. For all the mfg's at the time it was 6 months. Not sure about lightning's but you might want to check. For me, I don't like waiting, when I decide I want something the money starts burning through my pockets:) I could not find a WCM or lightning frame to save my life... Finally found one WCM Cage car chassis, but didn't want to learn how to assemble a car from scratch just to start racing.
Also, just a straight frame, not even a roller as in the $800-1200 range. A complete car/w engine for $1300 has even got my eye on it:)
LBJ
Post by LBJ »
My bad on the roller. Just sounds liker roller would be complete. So maybe 2300$ not so bad?? I have some time I think I am going to buy new. Unless I find that WOW deal. Thanks LBJ
KnoxMotorsports
Post by KnoxMotorsports »
WAY to much money for a car that has not proved to be worthy yet ,,,,It has not seen any QSAC events ,,The guy that builds it is a great guy and racer tho , A new wcm roll cage car is 1450.00 ,I have been doing this for awhile ,and racing WCM with great results ,,As one of the posts earlier , Race what the guys at your track is racin ,,for help unless you are an expert at setup ,, and ,,, or,,,have a ton of parts ,,that fit your car ,,, These car's after a wall hit or rub do break,unfortunately these car are not as strong as the smaller 10th scale cars,, Hope this helps ,,,not tryin to chase you away, Robert
Toe 2 Square alingment system
LBJ
Post by LBJ »
After alot of research and talking with guys at the track I decided a Lightning based chassis is going to be better for me. I will be racing at Freddies and most of the guys run Lightnings Rockits and Freddies new car[lightning]. This newby will need help. So it makes no since to buy some chassis noone is familiar with.Thanks for all of the repies LBJ!!!!
chiefj48
Post by chiefj48 »
Thank you!!!! let me know if you know of anyone looking for a car...
joe
