raco supermod/jackrabbit
smokinscott1977
Post by smokinscott1977 »
hi everyone i am new to the site and 1/4 scale in general i am attemting a raco supermod resto the car was 90% complete when i got it i am in need of some help though 1., where can i get a new clutch and maybe clutchbell still the stock zenoah g2b 2., the front tires are shot they are the 2 inch wides what is the best replacement for these 3.,the rear tires appear to be slicks but had a band glued to the outside , I removed the band and am in the proccess of cleaning the old glue can these be ran like that or do they need bands thanks . sorry to sound dumb but 1/10 scale is all off the shelve 1/4 scale is more hand built and personal whichis what drew me to it thanks for your time
Tom The Printer
Re: raco supermod/jackrabbit
Post by Tom The Printer »
Look up the Guys at BRP they'll have tires for you
Tom The Printer
Venomusss
Post by Venomusss »
Clutch can be found a Dave's Discount Motors. If your Rims are 4" Diameter BRP will have tires for you. If you have the most common 3" Diameter rims, then BRP can't help you. I am looking for the same tires you are for 3" rims...... If you find some let me know. :D
smokinscott1977
thanks for the help guys another quick question what is the best way to remove the front tires well the little bit that is left :lol:
cryo-tek
Post by cryo-tek »
To get the old tire off try soaking the tire and rim in paint thinner for a few hours. The foam will almost fall off of the rim. :o 8)
I have not done this with the chrome plated rims so I don’t know if it will cause the plating to release from the nylon rim.
