Conley V-8 With Stand
chiefj48
Post by chiefj48 »
hey all,
i am going to sell my Conley V-8 Engine #000069 with engine stand. as far as i know this engine was never run....
$3500.00 firm.....
i you have any interest please email me......
thank you.....
Annihilator
Re: Conley V-8 With Stand
Post by Annihilator »
any pics?
chiefj48
Post by chiefj48 »
http://www.quarterscalelegends.com/bb/v ... f=3&t=2206
there are pictures of it listed above.....
scroll down till you see my post with my engine..... :D
chiefj48
Post by chiefj48 »
dtw wrote:Chief
Does it come with the ignition leads and glow driver unit?
They're not pictured.
Dan
YES...... :D
I also have the original instructions.......
send me an email if you would like pictures.......
chiefj48
Post by chiefj48 »
not sure if this posted......
chiefj48
Post by chiefj48 »
cant seem to get them to post sorry....
chiefj48
Post by chiefj48 »
Thank You Mike........ :D
JariV
Post by JariV »
I'm asking this because I just don't know:
Are these engines mainly built for static display purposes and only running them in a test stand or can it be used for powering an rc?
Does it have an operational water pump? Looks like it has but I've just never seen one of these in real life and am wondering if the costs is the only reason or if there are other reasons too for people not willing to use these engines. Any idea of the power output and amount of usable rpm's?
chiefj48
Post by chiefj48 »
JariV wrote:I'm asking this because I just don't know:
hi,
yes it has a water pump, and i believe it has between 5-7hp, as far as rpm's, i'm just guessing at 15,000, and i'm sure someone on here might have a correct number if i'm incorrect..... they use nitro fuel, and need to be oiled down after use. again someone else might be able to answer that question these engines are not cheap, and as such are well cared for. most use these engines in hi-end cars, and not your every day driver.
i hope that i answered you questions....
joe
I would recomend static only. No parts are available for these at all. They rev VERY fast, its easy to throw a rod if your not careful. Plus they need to be cleaned very carefully after running and lubricated or the piston rings will rust to the cylinder sleeves.
Cool to run once to hear and see it, but not really worth the risk or effort to do often.
chiefj48
Post by chiefj48 »
FuNkY mOnK wrote:Also does it have ignition, plugs and wires? Can you give overall dimensions? Thanks.
yes i have the ignition box, wires, and plugs.....
14" long x 6" wide x 7" tall
chiefj48
Post by chiefj48 »
i also have the original assembly instruction, and breakin papers.......
chiefj48
Post by chiefj48 »
FuNkY mOnK wrote:Thanks Joe. is this the 427?
no, the 427 has the blower on it.....
other then that i believe they are the same bottom end....
plus my engine has the ram horn exhaust......
chiefj48
Post by chiefj48 »
QSL wrote:I would recomend static only. No parts are available for these at all. They rev VERY fast, its easy to throw a rod if your not careful. Plus they need to be cleaned very carefully after running and lubricated or the piston rings will rust to the cylinder sleeves.
Hey Mike,
How many of these do you have???
Would you agree that putting a Conley V-8 in any car puts it in a league all by itself????
These engines are for BIG BOYS, and they are the finishing touch for the MASTER Model Builders.....
Just Saying.....
:D
