hello from France
If you are a new member, introduce yourself here.
laurent
hello from France
Post by laurent »
hello , I am laurent the new boss of Yankee
The projects are many and the passion always !
I do everything I can to continue has to make live the legend of 1/4 scale models.
Respectfully,
Laurent
Re: hello from France
welcome to the site!!!
Did you acquire a lot of parts and tooling?
laurent
Post by laurent »
Many tools are saved , all plastics injection molds .
A big part of the molds of body , jaguar LM , Porsche , P4 330 , GT 40 , calibra DTM , F1 Benetton , Cross control 1/6 , Twingo , Spider 905 ...
905 LM will be available in 1 or 2 month !
see on the shop new production in ABS bodies (p4 330 , Twingo , and GT 40 Available at the end of the week ).
laurent
Post by laurent »
Hello and thank you for your order ,
Yankee is in full change but we make very attention to respect historic made.
We are now a small structure and we shall be happy to receive you !
Your parcel is ready and leaves with all the necessaires protections tomorrow.
:wink:
laurent
Post by laurent »
Hy Emilio !
Thank you for your post .
to cuting the P4 body , my advice :
- first cut the body
- after for the wheel use a compass for lexan for a 200mm diameter hole , the good distance for the center is :
123mm from the vertical line behind the front wheel (front center)
467mm from the vertical line behind the front wheel (rear center)
- be careful with the side stays for drill the 4 holes compare the 2 parts , adjust the body position .
Laurent
laurent
Post by laurent »
I post a topic with pic for the cutting :
http://www.quarterscalelegends.com/bb/v ... =20&t=3610
