RC4WD install.
big maestro
RC4WD install.
Well I've got the rear ready to bolt in a car. After I do some testing I'll let everyone know whats going on with it. I will have the parts made to convert any skellenger car over to the rc4wd rear. It will be a direct drop in.
Re: RC4WD install.
Very cool Big!
Re: RC4WD install.
Formidable
big maestro
Re: RC4WD install.
Well, I've been trying to upload pics of my progress and it keeps telling me the image is invalid.
Oh well...
Oh well...
Re: RC4WD install.
good job Big m
big maestro
Re: RC4WD install.
I tigured out why I couldn't post pics. So here goes. This is the rc4wd rear in a newer WCM grand national chassis.
Re: RC4WD install.
Looks great ,,Are they wcm trailing arms ? and for my learning why is the left trailer arm up side down to the right or vicer verser..
thanks
thanks
big maestro
Re: RC4WD install.
Yes. Im trying to use as many stock parts as I can. The left trailing arm is upside down because usually the bear carrier goes to the inside because the gear hub goes on the outside. Of course with this set up I dont need to do that. This puts the bearings as far out as possible to the wheels.
Good eye btw...lol
Good eye btw...lol
Re: RC4WD install.
Great work!
Does your rear end still have a functional diff? If so how did you keep both splined output shafts from pulling out of the diff?
I am using C-clips sandwiched between bearings to hold mine.
big maestro
Re: RC4WD install.
No, I eliminated the diff altogether. I wanted to make the rear a direct drop in for a skellenger car. So with a solid 1/2 in. axle you can use standard bird cages/ trailing arms etc. Do you have pics of your install?tamkyo wrote:Great work!
Re: RC4WD install.
Hey Big how did you eliminate the diff? Just ordered one and want to do what you did. Thanks in advance for any info you provide. Geoff
big maestro
Re: RC4WD install.
I just made a gear clamp like a skellenger and put a 1/2 inch axle straight through.CALracing wrote:Hey Big how did you eliminate the diff? Just ordered one and want to do what you did. Thanks in advance for any info you provide. Geoff
Re: RC4WD install.
Then I used the clamping screw to hold all the bearings in place. I am not sure why this clamping screw is there because in the stock RC4WD rear end, this clamping screw doesn't do a thing but it helps me in converting this so I am happy about that. Now with this screw tightened in place, I hold both axles in place without moving.
