I been planning to build something for a while, had plans for 3 seperate models but couldnt get a start.
Well i got to spend some quality time in the shed today, after trying to clean up for 1/2 an hour or so i got bored and thought about doing something real.
Heres the result of a day in the shed, gonna have to try and keep pushing, i want this one running under its own power!
OK i decided to combine two of my plans (means i only have 2 models not three in the planning lol) so i combined the dragster and model T C cab to get an old school dragster........
I had the blanks cut for the sides and the roof already but when they`re flat sheet its not exciting, so with a bit of work they look like this now
so after a few hours of banging and hammering i have sides and roof with lips and wired edges formed.
Then i had to form the cowl, i made a hammer form or buck to work on from some scrap steel and a block of tassie oak
Once you have your buck set you need to work out your material blank pattern.
So i get out my cad equipment (thats Cardboard Aided Design for those of you that didnt know)
and you wind up with this
from this you cut the material, in this case aluminium sheet (roof sheet off cuts from work) and with a little work you get this
note the beer can for scale
heres the pocket bike engine i`m planning to use up against the side panel
and heres the dummy engine i was planning to use on the dragster, should look good in this with a little work (beer can again for scale)
I have got to keep pushing to actually get this done, need to raid the scrap bin at work and get started on the chassis
